ghostismyname Posted February 3, 2012 Report Posted February 3, 2012 Ok being as this is a newer car (to me it is) I want to install my wires as cleanly as possible(no cuts) So i was wondering if anyone out there has or has had a explorer and where they may have placed there grounds( i dont have enough 1/0 to reach the neg on battery terminal from the rear). I dont really much care if the wire is not hidden, because i mean come on it 1/0, it just looks cool in my opinion. More info on the vehicle its 1998 2door sport explorer. Ive heard of grounding to the seat mounting points but that apparently can cause road static from what ive been told? Any help is appreciated. Also for potential curious readers (if any) I plan on putting two aq hdc4 18"s with two aq 2200d @ .5 ohm and prolly some batts.
BobbyG2 Posted February 3, 2012 Report Posted February 3, 2012 Seems to me everyone grounds to the frame *New vehicle and system coming soon.*
CrazyCricket12 Posted February 3, 2012 Report Posted February 3, 2012 Seems to me everyone grounds to the frame x2
ghostismyname Posted February 3, 2012 Author Report Posted February 3, 2012 Seems to me everyone grounds to the frame x2 well thats the general idea, i guess im looking for a more specific answer, like anyone who has had a explorer, where specifically in your rear space did you place your grounds?
EricM9104 Posted February 3, 2012 Report Posted February 3, 2012 i drilled a hole under the backseat, use a grommet, stuck wire through there and attached to frame, than sealed up the hole to keep elements out, and primered the ring terminal and frame to prevent rust 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
ghostismyname Posted February 3, 2012 Author Report Posted February 3, 2012 i drilled a hole under the backseat, use a grommet, stuck wire through there and attached to frame, than sealed up the hole to keep elements out, and primered the ring terminal and frame to prevent rust Thankyou
