SilveradoGoesBang Posted February 5, 2012 Report Posted February 5, 2012 I was checking my ohm load with multi meter and it was jumping everywhere but once I held It still it was 1.2 is that normal? It's two d4 subs to 1 ohm never used a multimeter before so idk if it's normal when u don't hold it still for the ohm load to jump around "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
bumonskateboard6 Posted February 5, 2012 Report Posted February 5, 2012 Sounds normal to me, most jump around until they get a stable reading. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
__d_a_v_i_d__ Posted February 5, 2012 Report Posted February 5, 2012 Sounds like a perfect load . Put ur DDM to os, touch the leads and if it's not at zero, whatever number it shows you'll substract that on your final ohm. For example mine says 0.5 when I touch leads, so when my final load was 0.5 It showed has 1 ohm on my ddm . Also every coil is not perfect, like of your have d2 coils it may read from 1.8-2.4 get me ? so that would also change final load by a few tenths. But sounds good to me . Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
Tarball Posted February 7, 2012 Report Posted February 7, 2012 Also consider the length and gauge of your speaker wire. This can add to your overall circuit resistance value. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
