Does anyone know or have ideas on how to make the top piece as a solid part?
I think part of the problem is "non continous" lines, as they are build up of many small ones to get the desired shape. If I click on one of the lines only a small section of it becomes blue. Although the are still connected to another. I'm sure those who use SketchUp will understand.
I did manage to make walls on part of the small end where the lines are actually straight. (not shown in the pic)
I would really apreciate some good tips and tricks!
Maybe take just one of the lines, and pretty much copy it towards the center of the circle so it will make a "thickness" of that line, then click on the "follow me" option under the tools tab, and follow it around the outside of the speaker ring so it takes that shape. I dont know if it will work or if you will understand anything I just said because its really hard to explain without showing you.. lol
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
wow...... I guess i have to play around with it a little, if it even works. If i can't do it I'll blame it one the cold I have :rolleyes:
Looks like it kind of worked:
Then again....:
