Ok so the AQ SDC2.5 work best on 4-4.5 cuft per sub and 14-15 sqin/cuft so you are low, here is a design suggestion on your space:
Enclosure Specifications:
Fb = 32,351 Hz
Vb = 7,67 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 17 in
External Width = 38 in
External Depth = 30 in
Port Width = 6 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 31 1/4 x 15 1/2
Front Internal = 30 1/2 x 15 1/2
Back = 38 x 15 1/2
Left & Right Sides:
Side 1 = 28 1/2 x 15 1/2
Side 2 = 27 3/4 x 15 1/2
Top & Bottom = 38 x 30
L Port Internal Assembly Parts:
Front to Back = 19 1/2 x 15 1/2
For your type of vehicle is recommended subs/ports in the same face front or rear firing so both should be tried.
Here is an assembly guide (generic dimensions):
Edited by Joe X
Fb = 32,351 Hz
Vb = 7,67 ft^3
Port Width = 6 in
Cut List:
Back = 38 x 15 1/2
Left & Right Sides:
thanks i will get some wood and get it pput together!
for that sub you can tune higher.. try a tuning closer to 35-36 htz youll be alot happier and it will free up some room in your box
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
thats what i was thinking them subs like it at around 36-38.... i am currently building a box for these same subs but i got it tuned to around 35-36. right now i have them in a box thats tune to 39-40 its ok but im building a new one to tune lower. good subs by the way
what would i need to change on the box design above for it to be tuned around 35hz?
port length mostly
Edited by KenC210
what wattage do u have urs at, cause mine are on 500wrms and they make a popping sound when i go 3/4 to full tilt.
ive had up to 2k on these subs and they took it with no problem.. post a vid of the sound and see if someone could figure it out..not the best at diagnosing a problem without being there but someone could prolly give suggestions
power: dd m4
  • Who's Online   0 Members, 0 Anonymous, 804 Guests (See full list)
