garrett30 Posted February 6, 2012 Report Share Posted February 6, 2012 I am wanting to do a rebuild with my new AQ sdc2.5 15's and need a little help with designing a box. Anybody on the forum intersted in helping a fellow basshead out? Quote Link to comment Share on other sites More sharing options...
garrett30 Posted February 6, 2012 Author Report Share Posted February 6, 2012 I have 2 AQsdc2.5 15's and the dimensions are 38"Wx30"Dx17"H. I would like the tuning at 32hz and i have a 1999 ford contour. Quote Link to comment Share on other sites More sharing options...
Joe X Posted February 6, 2012 Report Share Posted February 6, 2012 (edited) Ok so the AQ SDC2.5 work best on 4-4.5 cuft per sub and 14-15 sqin/cuft so you are low, here is a design suggestion on your space: Enclosure Specifications: Fb = 32,351 Hz Vb = 7,67 ft^3 Subwoofer Mounting = Flush Mounted External Height = 17 in External Width = 38 in External Depth = 30 in Port Width = 6 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 31 1/4 x 15 1/2 Front Internal = 30 1/2 x 15 1/2 Back = 38 x 15 1/2 Left & Right Sides: Side 1 = 28 1/2 x 15 1/2 Side 2 = 27 3/4 x 15 1/2 Top & Bottom = 38 x 30 L Port Internal Assembly Parts: Front to Back = 19 1/2 x 15 1/2 For your type of vehicle is recommended subs/ports in the same face front or rear firing so both should be tried. Here is an assembly guide (generic dimensions): Edited February 6, 2012 by Joe X Quote Link to comment Share on other sites More sharing options...
garrett30 Posted February 6, 2012 Author Report Share Posted February 6, 2012 Ok so the AQ SDC2.5 work best on 4-4.5 cuft per sub and 14-15 sqin/cuft so you are low, here is a design suggestion on your space: Enclosure Specifications: Fb = 32,351 Hz Vb = 7,67 ft^3 Subwoofer Mounting = Flush Mounted External Height = 17 in External Width = 38 in External Depth = 30 in Port Width = 6 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 31 1/4 x 15 1/2 Front Internal = 30 1/2 x 15 1/2 Back = 38 x 15 1/2 Left & Right Sides: Side 1 = 28 1/2 x 15 1/2 Side 2 = 27 3/4 x 15 1/2 Top & Bottom = 38 x 30 L Port Internal Assembly Parts: Front to Back = 19 1/2 x 15 1/2 For your type of vehicle is recommended subs/ports in the same face front or rear firing so both should be tried. Here is an assembly guide (generic dimensions): thanks i will get some wood and get it pput together! Quote Link to comment Share on other sites More sharing options...
pa-pa-platypus Posted February 6, 2012 Report Share Posted February 6, 2012 for that sub you can tune higher.. try a tuning closer to 35-36 htz youll be alot happier and it will free up some room in your box Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4 Link to comment Share on other sites More sharing options...
KenC210 Posted February 6, 2012 Report Share Posted February 6, 2012 for that sub you can tune higher.. try a tuning closer to 35-36 htz youll be alot happier and it will free up some room in your box thats what i was thinking them subs like it at around 36-38.... i am currently building a box for these same subs but i got it tuned to around 35-36. right now i have them in a box thats tune to 39-40 its ok but im building a new one to tune lower. good subs by the way Quote Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra Link to comment Share on other sites More sharing options...
garrett30 Posted February 6, 2012 Author Report Share Posted February 6, 2012 for that sub you can tune higher.. try a tuning closer to 35-36 htz youll be alot happier and it will free up some room in your box thats what i was thinking them subs like it at around 36-38.... i am currently building a box for these same subs but i got it tuned to around 35-36. right now i have them in a box thats tune to 39-40 its ok but im building a new one to tune lower. good subs by the way what would i need to change on the box design above for it to be tuned around 35hz? Quote Link to comment Share on other sites More sharing options...
KenC210 Posted February 6, 2012 Report Share Posted February 6, 2012 (edited) for that sub you can tune higher.. try a tuning closer to 35-36 htz youll be alot happier and it will free up some room in your box thats what i was thinking them subs like it at around 36-38.... i am currently building a box for these same subs but i got it tuned to around 35-36. right now i have them in a box thats tune to 39-40 its ok but im building a new one to tune lower. good subs by the way what would i need to change on the box design above for it to be tuned around 35hz? port length mostly Edited February 6, 2012 by KenC210 Quote Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra Link to comment Share on other sites More sharing options...
garrett30 Posted February 6, 2012 Author Report Share Posted February 6, 2012 for that sub you can tune higher.. try a tuning closer to 35-36 htz youll be alot happier and it will free up some room in your box thats what i was thinking them subs like it at around 36-38.... i am currently building a box for these same subs but i got it tuned to around 35-36. right now i have them in a box thats tune to 39-40 its ok but im building a new one to tune lower. good subs by the way what wattage do u have urs at, cause mine are on 500wrms and they make a popping sound when i go 3/4 to full tilt. Quote Link to comment Share on other sites More sharing options...
pa-pa-platypus Posted February 6, 2012 Report Share Posted February 6, 2012 for that sub you can tune higher.. try a tuning closer to 35-36 htz youll be alot happier and it will free up some room in your box thats what i was thinking them subs like it at around 36-38.... i am currently building a box for these same subs but i got it tuned to around 35-36. right now i have them in a box thats tune to 39-40 its ok but im building a new one to tune lower. good subs by the way what wattage do u have urs at, cause mine are on 500wrms and they make a popping sound when i go 3/4 to full tilt. ive had up to 2k on these subs and they took it with no problem.. post a vid of the sound and see if someone could figure it out..not the best at diagnosing a problem without being there but someone could prolly give suggestions Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4 Link to comment Share on other sites More sharing options...
