for that sub you can tune higher.. try a tuning closer to 35-36 htz youll be alot happier and it will free up some room in your box
thats what i was thinking them subs like it at around 36-38.... i am currently building a box for these same subs but i got it tuned to around 35-36. right now i have them in a box thats tune to 39-40 its ok but im building a new one to tune lower. good subs by the way
what wattage do u have urs at, cause mine are on 500wrms and they make a popping sound when i go 3/4 to full tilt.
ive had up to 2k on these subs and they took it with no problem.. post a vid of the sound and see if someone could figure it out..not the best at diagnosing a problem without being there but someone could prolly give suggestions
ok i will see if my camera can pick it up tomorrow.
Posted (edited)
The SDC2.5 are very different to the HDC3s still 33-35 would have been probably more like it, for the HDC3 35-38 will sound much louder.
For a 33 tuning just change this:
L Port Internal Assembly Parts:
Front to Back = 17 3/4 x 15 1/2
For higher tuning a redesign is needed because of port area per cubic feet goes below recommendation.
Edited by Joe X
ive had the 2.5 before and the best success i had was with 35 htz tuning
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
mine are seeing roughly 900-1100... i got each sub wired at 2ohm with a kicker zx1000.1 to each sub
  • Who's Online   0 Members, 0 Anonymous, 623 Guests (See full list)
