BassMunky Posted February 7, 2012 Report Posted February 7, 2012 How can you tell if the subs are blown? any test suggestions? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
rocking.that.eclipse Posted February 7, 2012 Report Posted February 7, 2012 You can check it on an amp you know is working, hook up to a 9 volt battery, try pushing down on the cone and listen for a rubbing noice... depends on what could be wrong.
the1uwannab Posted February 15, 2012 Report Posted February 15, 2012 You can meter the coils and see if they are reading at what ohms they are supposed to bee at or you can put a battery like he said above which will move the sub if it works also if you can get a hold of a tone generator to do the same.
NT_Hardcore Posted February 15, 2012 Report Posted February 15, 2012 dmm. test for imp. if its frozen its obv. no good.
BassMunky Posted February 24, 2012 Author Report Posted February 24, 2012 thankyou Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
