MrSkippyJ Posted February 7, 2012 Report Posted February 7, 2012 how did you check the fuses though? just looking at them? Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Ragehole Posted February 7, 2012 Author Report Posted February 7, 2012 yeah, they are all clear so you can see right through them to see if the metal inside is broken. there are no loose wires and no corrosion on any termanal or wire or fuse. Quote
varietyguy Posted February 7, 2012 Report Posted February 7, 2012 It sounds like a relay to me.turn your key to accessory on and listen for any ticking. Quote 1992 Mazda 323 http://www.stevemead...323-wall-build/
MrSkippyJ Posted February 7, 2012 Report Posted February 7, 2012 yeah, they are all clear so you can see right through them to see if the metal inside is broken. there are no loose wires and no corrosion on any termanal or wire or fuse. check them with a DMM anyway. it is not uncommon for a fuse to be bad with no visible signs of being bad. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Ragehole Posted February 8, 2012 Author Report Posted February 8, 2012 so i found a fuse under the hood that i didnt check kuz i didnt think it would have to do with the radio. and i replaced it and the radio worked for about 5 minutes and then kicked the fuse out again. now every time i try to replace the fuse, the second i put the new one in it pops the new one. any ideas. thinking a ground issue somewhere or possibally a positive wire touching somewhere? Quote
varietyguy Posted February 8, 2012 Report Posted February 8, 2012 You've got a short somewhere. pull the head unit out and unplug the harness, then put in a fuse and see if it still pops. Quote 1992 Mazda 323 http://www.stevemead...323-wall-build/
Ragehole Posted February 8, 2012 Author Report Posted February 8, 2012 thats what i was thinking about doing. this is actually the second pioneer headunit of this type. the first one also did this same thing. i will let you guys know what happens. Quote
Ragehole Posted February 9, 2012 Author Report Posted February 9, 2012 i pulled the head unit and switched the fuse with it out and it seemed to have worked for now. i will report back if i have any more problems with this issue. thanks every body who had something to say. i really appreciate it. I really missed my beats. Bassheads for life!!!! Quote
Ragehole Posted February 9, 2012 Author Report Posted February 9, 2012 so im still having the issue.... i found these 3 wires comming out of my rear view mirror that had come disconnected. idk if those may have anything to do with why the fuse keeps blowing but i also noticed that my sunroof doesnt work either now. they must all be tied into eachother on that fuse. could these wires from my mirror touching be enough to short that fuse out. they are for my lights that are in the mirror? i have taped them off for now till i can get it fixed. my windshield flexes like an inch and a half or so when the bass is on so i think that my be my short... let me know what you guys think. Quote
Ragehole Posted February 10, 2012 Author Report Posted February 10, 2012 the 3 weres where the issue. i got everything fixed up and it works like a champ now. thanks for everybodys input i appreciate it. Quote
