Relyks Posted February 8, 2012 Report Posted February 8, 2012 its not turning on like it turnsover but its like no gas is getting to the engine i got spark just not firing up... ( just had new plugs,wires,cap,oil change,new battery,new fuel pump, new gas tank. ) like couple months ago but it has driven since then. ill reply fast if you got questions its a 1991 toyota 22re fuel enjected stock parts mainly 100k miles. Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
727Designs Posted February 8, 2012 Report Posted February 8, 2012 Do you hear the fuel pump cycle over when you turn the key on? Quote -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD-
photochrisb931 Posted February 8, 2012 Report Posted February 8, 2012 (edited) Like 727 said, either listen for the fuel pump to click and cycle or if you can not hear it from the driver seat get someone to turn the key on and you listen to the fuel pump from the fuel fill with the cap off. That said the guides for the timing chain on the 22re are notorious for breaking, hence the only timing chain I know of that recomends replacement every 70-90k because the guides wear out. I have seen the chains with enough slop that have taken out the crank sensor which would cause a no start issue. That is a worse case situation but not uncommon. Edited February 8, 2012 by photochrisb931 Quote Barstad
Relyks Posted February 13, 2012 Author Report Posted February 13, 2012 bad ground on engine block and body caused fuel pump only 4volts of power now im sitting at 13 volts. so thanks for help. Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
