The Black Nasty - 6 HDC4 15s + 6 Q1-3500D.1s = 162s on music!!!
Dem recones doe.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Should make a HDC4BN with a little more cooling and maby a bigger motor or a extra spider lol
less fires, Lmao
Theres really no nice way to say this. You are a moron.
Damn. I'm suprised you haven't started chafing from riding soundqubed dick so much. Its obvious he was joking
Ok guys, lets not throw anymore fuel on the fire ,,,,,,,,,, see what I did there :)
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
A reputable source told me that a certain build house of 3500s (not sure of aq/sq is part of them) is causing a lot of issues with one of the leads (don't remember if it was the positive or negative). It causes the lead to get extremely hot and ends up in melting the solder which eventually ends up ruining the lead. They tried diagnosing the issue by switching the polarity to see if it had the same effect on the lead that was getting destroyed and it did. Idk if this applies to you but I hope it might help. I know you said the issue was extreme clipping but I thought you might find this helpful.
Team Bass-Hz
Thanks for the tip, do you have any additional info on this. Cuz the AQ/SQ 3500s are a different board then the standard DC, Sundown, Crescendo 3500.
Evo X build log
And are you talking about the lead internal on the amp? Cuz I don't have any amp failures, issues.
Evo X build log
not sure if it was mentioned before but all the caps are wired to battery bank and then from caps to 6 bass amps?
not like the two amps u added are wired to caps and 4 to batteries??
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
It's not zenon I think it started with a J I for got the name bro. The person that told me about this to had to do with the amp internals. On your leads did both get torched or was the fire only caused by one either the positive or negative leads?
Team Bass-Hz
The fire was caused from the coil getting so hot the former caught on fire and, coil unwound, shorted and quit playing, cause the coil is now open, sub stopped moving, other subs barely moving, fanning the flames, and the flame came straight up cuz fire burns up not down, two direct leads were laying on the motor directly above the fire, those caught on fire from the open flame.
I check all my amps a few days ago and all of them are functioning fine thru an oscope.
Evo X build log
alts to batts, batts to caps, 4 amps on batt bank, 2 amps on cap bank, every amp sees same voltage, and voltage drop, battery bank drops pulls caps down instantly. If I stay above resting voltage caps hold voltage up and never moves at any amp. I can only get drop under heavy clipping.
Evo X build log
  • 3 weeks later...
Updates anyone? meh no one ever wants updates :)
Turkey drag is gonna be fun.....
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 5442 Guests (See full list)
