The Black Nasty - 6 HDC4 15s + 6 Q1-3500D.1s = 162s on music!!!
So on your last wall, there was actually dead space in between the ports? Wouldn't that have hurt your score?
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
is there such thing as "bowling" waxing the inside of the box? basically it's as frictionless as bowling lanes?
Yes and it has been done :)
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Yes, verified possible area of turbulence with a smoke machine and air nozzle, it most likely hurt my score by .5 - 1 db. So a lot of areas of improvement has went into the design and building of this wall. Should be some "good" numbers this go around too :)
Evo X build log
So on page 19, you basically just did that to the inside of the box to get the "frictionless" finish
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Sounds like you've stayed up extra late and done your homework for this one ;)
under construction
u hate c-fizzy?
Yes, there is a few extra steps prior to paint that I did but paint steps were the same as listed on page 19 except glaze pro buffing step wasn't done because it wasn't needed as I didn't have to wet sand that much, just had to block out dust in the clear in a few spots. And at this point I just keep adding coats of wax to make it smoother and smoother inside the port area.
Evo X build log
Just wait once you see how I brace the baffle, it will be rock solid.
Evo X build log
Looking real good! Liking the idea of steel going in the baffle!
midwestspl
2008 basic 2 144.6
2008 xtreme 3 126.3
2009 adv 3 156.2 3rd place
2009 xtreme 3 138.0 champ
2009 incriminator point cup champion
Update 9/7/12
Got the steel I needed yesterday, this is what I am working with for the front baffle, got the second layer of mdf cut as well. Got a plate just big enough to add strength where it is needed.
Going to cut it out in a few days with a friends plasma cutter.
1/4 thick steel
Here is my brace bars that will be welded to the plate and then bolted to back wall of shell. Solid steel.
1 inch thick, these will be cut to length and welded to some 3 inch diameter round 1/4 plates and bolted to back of shell.
Some of the lags and machine bolts that will be used to bolt this all in place once welding is complete. Lags are 1/4 shank grade 5 and machine screws are 1/4 inch shank zinc coated steel.
More awesomeness soon to fap fap fap fap fap too!!!!
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 470 Guests (See full list)
