Decaf Posted February 13, 2012 Report Share Posted February 13, 2012 you should not use that knob. its a signal booster at 45hz from 0-18db reset with dd-1 not using bass knob and see how you like it, starting with -5db for safer setting until you stop smelling coil Quote Link to comment Share on other sites More sharing options...
NickTheBassHeadCook Posted February 13, 2012 Author Report Share Posted February 13, 2012 I'm pretty sure this knob is a gain knob and not a bass boost, it doesn't go past the limit set on my amplifiers gain Quote Link to comment Share on other sites More sharing options...
Decaf Posted February 13, 2012 Report Share Posted February 13, 2012 if it says 0-18db is a bass boost knob "KICKEQ™ Boost: Variable to +18dB (ZX300.1 selectable +12dB), centered @ 40Hz" Quote Link to comment Share on other sites More sharing options...
NickTheBassHeadCook Posted February 13, 2012 Author Report Share Posted February 13, 2012 It says 0 to 11 on it the same as the numbers for the gain on my amp. Quote Link to comment Share on other sites More sharing options...
Decaf Posted February 13, 2012 Report Share Posted February 13, 2012 (edited) whats ur model number, specifically the year i missread when googling, you DO have a level control remote. just make sure you are not using the bass boost on amp nor heaunit Edited February 13, 2012 by Decaf Quote Link to comment Share on other sites More sharing options...
NickTheBassHeadCook Posted February 13, 2012 Author Report Share Posted February 13, 2012 It's an 11zx1500.1 I was reading about this a while back to make sure and i found that its gain control, I could be wrong though, it is the Internet... Quote Link to comment Share on other sites More sharing options...
Decaf Posted February 13, 2012 Report Share Posted February 13, 2012 you're fine, been a long day and i confused the boost on amp with remote, just reset using -5db and that should get rid of the problem and your system will just be a bit quieter or continue to use -10db and just dont go full tilt volume on every song unless you know its clean enough to do so Quote Link to comment Share on other sites More sharing options...
FroznBeavrBALLs Posted February 13, 2012 Report Share Posted February 13, 2012 maybe your wire is what was smelling... too much power threw a small wire will burn it up. Quote 2 DC 12" lvl 4s 1 DC 1.2k XS Power S3400 big 3 Alll KNU wire Pioneer HU cheapo Legacy coaxes (just for now) http://www.stevemead...n-sentra-build/ Link to comment Share on other sites More sharing options...
getlocivic Posted February 14, 2012 Report Share Posted February 14, 2012 ^^10g wire is PLENTY for what hes doing he wAS using a shitty mixtape track thats why he smelld coils.. even tho u have gains set with a dd1 it dont help any if you play clipped music lol.. decaf already mentioned that Quote Link to comment Share on other sites More sharing options...
