NickTheBassHeadCook Posted February 13, 2012 Report Posted February 13, 2012 I have two l515 kicker solobarics dual 2 ohm and they are wired to 2 ohms on a kicker zx1500.1 amp. Everything is wired correctly and the gains are set with the dd-1. So everything is exactly how it should be. I re wired my subs with some nicer 10awg speaker wire yesterday and hooked it all back up and once I started playing it loud for a while my subs got the bunt voice coil smell, I double checked to make sure it is all wired the right way and it is. The gain is still set where it has been, but I'm still getting the smell, it didn't start till after I re wired the subs so I'm thinking the wiring may be the cause. Im not sure. Help me out! Quote
OrionStang Posted February 13, 2012 Report Posted February 13, 2012 Double check how your wired. What track did you use, hope it wasn't the -15db track. Are your subs new or used? Quote SMD Super Seller My Feedback Thread
Sanitarium Posted February 13, 2012 Report Posted February 13, 2012 try checking the output of your amp with the dd-1 again with the subs still hooked up. I never did get why they say to unhook your subs to test it, your subs load the amp, the amp draws power, the voltage drops, then the clip ceiling falls and boom. what was once clean with no load is now clipped to shit. Quote
NickTheBassHeadCook Posted February 13, 2012 Author Report Posted February 13, 2012 I used to -10 db track I'm pretty sure, its the compromise of the sq and spl. everything is wired right I just checked for the third time. Checking it with the dd-1 while the subs are connected won't damage the subs at all? And yes the subs are brand new, I just got them 2 weeks ago and they worked fine until I switched to kicker 10awg. But I know or a fact it's not the wiring. Quote
NickTheBassHeadCook Posted February 13, 2012 Author Report Posted February 13, 2012 This is my first kicker set up and I loved it compared to my old 12s, but I need to figure out why this is happening. I've read a lot about kicker voice coils sucking ass. Quote
Dan2427 Posted February 13, 2012 Report Posted February 13, 2012 I had L7s and they stunk no matter what they never got hot but they stunk from when I got them and sold them. Quote 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
NickTheBassHeadCook Posted February 13, 2012 Author Report Posted February 13, 2012 So this is normal? That doesn't seem right... Quote
Decaf Posted February 13, 2012 Report Posted February 13, 2012 what song where you playing? if you play a song louder than the tone used to set gains with dd-1 you run the chance of clipping the amps output, in conjunction with voltage drop as current draw will increase and efficiency will go out the door. Quote
Socky Posted February 13, 2012 Report Posted February 13, 2012 This happens to my bros subwoofers to, running a aq2200d with 4 sa-15s d2 wired at 1 ohm and tuned with the dd-1, they are brand new and he got them started to smell for a short time and turned it down. Quote Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
SnowDrifter Posted February 13, 2012 Report Posted February 13, 2012 Try using the -5 or the -0 track. You might just be playing a song with a bass line that is louder than -10db and it's clipping Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
