im getting a fi 15" BL 1ohm with,cooling and flatwind,option... and most likly to get a hifonics brz1200.1 or hfi1500d not sure though... im wondering what type of alternater ill need and if ill need x-tra battery??? im already going to do the big 3
Stay away from the HFI line, other option is the http://www.ebay.com/itm/AUDIOPIPE-AP15001D-1500W-MONO-D-Audio-Amplifier-/230699972988?pt=Car_Amplifiers&hash=item35b6ca397c or the bigger brother http://www.ebay.com/itm/NEW-AUDIOPIPE-AP1800D-1800W-MONO-Car-Audio-Power-Amplifier-1800-Watt-/270849543318?pt=Car_Amplifiers&hash=item3f0fe40c96, AP is well known as bang buck brand.
Fececupe, have a ampclamptest on site 5 or 6 in the Ampsection, where he clamp 1800 watt´s out of a AP 1500 at 13.6 volts.
"in the abundance of water, the fool is thirsty" Bob Marley
i'd rather take that hifonics amp over a piece of shit audiopipe
edit: you should be fine with just the big 3. i wouldnt recommend playing at idle though (like a stop light) if you want to avoid dropping your voltage.
Edited by Kranny
do you have d1's or d2's?
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Depending on your stock alt, you may need nothing done except for the big 3.
I'd also replace the stock starter battery with an AGM battery.
  • Who's Online   0 Members, 0 Anonymous, 2546 Guests (See full list)
