Checklist:
[ ] Does the amp go into protect?
[ ] Do you have a multi meter??
[ ] Does the amp have power - verify with multi meter
[ ] Does the remote wire turn on - verify with multi meter
[ ] Do the RCAs have power going to them - verify with multi meter
[ ] Do the outputs on the amp have power going to them when turned up and speakers disconnected - verify with multi meter
[ ] Check subwoofer impedance at the amp with a multi meter
[ ] Do your subs read some bizarre ohm load - verify with multi meter
i would say check the sub wires again because i was rewiring my sub and wasnt paying attention and had both positives from the sub on the positive and negative to the amp. the result was no power
2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0
Build Log
UBL My YouTube channel
Checklist:
I really wish the like button worked.
What size wire are you running, where is your ground?
check your head unit. one time i was pissed cause i bought new everything and nothing played till i pressed the Sub On button haha
Blowthrough
Subs
rebuild
Amps
1-SAZ3500
1-T4004
Coaxial
1Set Alpine Type-R Components
1 Set- kicker ks 5.2
1 Set- Kicker ks 6x8
Reciever
Pioneer DEH-P7400HD
2000 Ford F-150 EXT Cab
Clarion EQ
actually just did that today and still nothing.
Checklist:
im running 1/0 and ground is on frame. amp turns on with my head unit so i know theres power going to it. it lights up when its on
did that too. that was the first thing i did. went through all my settings on my head unit.
Checklist:
If this is the case then the problem is in your amp or RCA's, or subs. find some random speaker and hook it up and see if it works.
  • Who's Online   0 Members, 0 Anonymous, 2413 Guests (See full list)
