77-AUDIO Posted February 14, 2012 Report Posted February 14, 2012 I need a box design for 1 - DC 8". I have a dodge caliber so theres plenty of room. would like to have the sub on one end and the port on the other. example box is 11" deep, 11" tall and 32" wide. want the sub on the 11" x 11" side and the port on the other 11" x 11" side. this way I can put groceries on the top and back of the box without affecting the speaker or port. max width is 34" thank you. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
Joe X Posted February 14, 2012 Report Posted February 14, 2012 Ok so here is a design suggestion for the DCL2 8" port/sub same face and around your dims: Enclosure Specifications: Fb = 36.096 Hz Vb = 0.91 ft^3 Subwoofer Mounting = Front Mounted External Height = 13 in External Width = 22 in External Depth = 11 in Port Width = 1 3/8 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 13 x 11 Left & Right Sides = 20 1/2 x 9 1/2 Top & Bottom = 13 x 20 1/2 L Port Internal Assembly Parts: Front to Back = 19 1/8 x 9 1/2 Extension = 4 x 9 1/2 Let me know any comments/questions.
77-AUDIO Posted February 15, 2012 Author Report Posted February 15, 2012 turn the port 90 degrees to the left and the sub 90 degrees to the right. want the sub facing the side of my car and the port facing the other side of my car. not sub and port facing the rear. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
Joe X Posted February 15, 2012 Report Posted February 15, 2012 Placing the sub and the port on opposite sides will lead to bad results. you can place this box with sub/port facing fowrard or in any case upwards, best configuration in most cases is port/sub on the same face. I did read your request before.
77-AUDIO Posted February 15, 2012 Author Report Posted February 15, 2012 Aight got ya. lets fo with these dimensions. 11" tall 12" deep and 36" wide (max width) and put the sub and port on same side in the 11"x 12" side. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
Joe X Posted February 15, 2012 Report Posted February 15, 2012 Would need to be 11"x13" to fit. I have updated the design above, the port would be above or below the sub on the lateral face, let me know if you need an assenbly guide.
412 CVX Posted February 15, 2012 Report Posted February 15, 2012 downfiring? 4th order? Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
77-AUDIO Posted February 16, 2012 Author Report Posted February 16, 2012 I have a dodge caliber so a down fire would work. But don't have a design. I do have one for the style that I was looking for. Well close to it. Port and sub are on the same side. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
412 CVX Posted February 16, 2012 Report Posted February 16, 2012 HIt me up and i can design you something. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
