large gauge crimper
hammer crimp and solder :)
this looks meh, I went so high up on the shink tube cause the mesh was starting to fray, so I hads ta fix it.
btw, I bought the HB crimper, its a POS, took it back that day, it would not fit real 0ga terminals.....
i use these cost me 150 but they are awesome
these are hands down the best out there. If I did more installs, I'd use these
actually not quite, those are usually 4-8ton mechanical crimpers depending on length of handle, those handles are pretty short compared to the 8-9ton mechanical crimpers (usually over 25" handle)... so dc98hoe spent $150 to have less crimping force than a $70 hydraulic crimp that comes with more dies.
I'd take off those lugs, strip a new chunk of wire, and just solder it. Those look like imminent doom
crimping is better.
There was a thread about crimping wire vs. soldering
but not in your case. i'd solder any day over having to use connections like that.
only if you're good at soldering lol. otherwise it looks oxidized to hell and back with a melted jacket and a dirty mud of solder at the tip
How do you know that my connection is bad? Just because it doesn't look pretty, doesn't mean it's bad.
well it does fine on copper lugs..if your crimping brass ones then id go with hydraulic..also you can change the crimp size on the fly they are built in to the head...yea i got got as far as price but they have done me well and crimps awesome..
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Hmm, it's time for me to upgrade my equipment lol.
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
