rca y splitter is what i use
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
But the third amp can't be running on a hpf because it's powering the subs in my doors, how would I work with that? Just turn it all the way down and use the crossover on the amp?
that pictures is for example only. otherwise just use Y's
NEUMAN
I just don't want to use Ys and cut the voltage in half, I have 2 4v preouts, id have to use a Y on one the rear/sub preout and in turn wouldn't that make my subs not hit as hard? Could I use a 2 way crossover going from the front preout on My HU to the crossover and run the lpf to the door sub amp and the hpf to the 4 channel, then use the rear/sub preout on my HU and go straight to the amp?
y spilters will not and do not split your voltage in half it will give 4 volts to both amps
thats like saying if you have a distro block on your power wire and 2 amps each amp will get 6 volts lol
oh noes 6 volts! LOL
NEUMAN
face palm.
1999 Lincoln Town Car-(build underway)
- (2) SA15s, 4th order, DAT 2500.1, O2 mids n highs, 250a alt, HC 2400, Big 3....
1994 Pontiac T/A for speeding tickets.-
- Currently on jack stands, wanting to be a real race car
"Your local forecast, all the ladies in the metro area should expect to see 8 inches tonight" - The Todd
Decaf, on 01 November 2011 - 02:38 PM, said:
i provide the ammo for destruction, the trigger finger is connected to the volume knob tho
URBAN GORILLA AUDIO
Damn, you guys are so smart. I'm learning. Dick. That's what I was told by someone just like you who thinks they are the "God" of car audio. Why does it honestly matter that you know more about it then I do? I'm learning, I've been doing this for a year. And I am actually capable of a lot more then you assholes think.
i really hope that was not to me all i did was help!!!!!
if you want me to be a dick/asshole i really can be ;)
