I have this 200 amp pac battery relay that I took out of my dads truck because he no longer needed his second battery, it was in his car for about 4 or 5 years so it was in there for quite a while lol...Is there a way I can test it to make sure it works correctly before using it in my car?
relay or isolator.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
do you plan on running your stereo with the car off for extended periods of time.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
relay or isolator.
isnt that the same thing?
1st off, you dont need it unless you like to sit with the car off, playing your system until the battery dies. if you are smart enough to not do that, you dont need one.
2nd. if it was working in his car until you pulled it out. then im sure it still works.
last, put power to the coil on the relay then take a dmm and measure resistance across the two poles. if you get a reading, it works. you should also feel the click from the relay when you power the coil.
relay or isolator.
1st off, you dont need it unless you like to sit with the car off, playing your system until the battery dies. if you are smart enough to not do that, you dont need one. - But it will be hooked up to my stock starter battery which is a lead acid...It was my understanding that different type batteries don't do good together in parralel?
2nd. if it was working in his car until you pulled it out. then im sure it still works. - He dissconnected his second battery quite a while ago so I didn't really have a way to see if it still worked good or not.
last, put power to the coil on the relay then take a dmm and measure resistance across the two poles. if you get a reading, it works. you should also feel the click from the relay when you power the coil. - This will work without the ground pole grounded even?
relay or isolator.
Perfect answer
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
relay or isolator.
pretty much. dont ask me why but I was thinking they functioned opposite after you posted that i had to stop and think abotu it. Retard moment for the day isover ill go to the corner now.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
relay or isolator.
lol well I've actually thought battery relays and isolators were two different things too for quite a while because I watched exocontraltos video on them and he described them as if they were two seperate things....
relay or isolator.
I say this all the time. Please do not rely on EXO for information.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 2546 Guests (See full list)
