i really don't know which one to use for my subwoofer amp. I've tried all of them, but with each different one, the gain seeting is different. I mainly listen to metal or dubstep. I want my system to be as loud as possible without distortion, but im pretty sure the music i listen to is the same dB as the track that says "for a louder system, use track..."
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
anyone?
2005 Subaru Impreza
My build log.
read the manual
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i did...many times. i wouldnt come here trying to waste anybodys time by not reading the manual first. One of the tracks says "use for a louder system", the other says "use for a compromise" or "use for sound quality".
The sound quality track isnt nearly loud enough for my likings, the "compromise" is alright, but i feel like my amp isnt pushing the subs to thier fullest potential, and i'm afraid the "loud system" track is giving too much distortion to my everyday listening music.
Edited by AB18VFL
2005 Subaru Impreza
My build log.
use track 3(-5dB/sq) or 5(-10dB/compromise) for sub amp, if you don't listen to bass heavy music(which you do) you can use track 7(-15dB/loudest)
if you are setting the amp with track 3 or 5 you are getting max CLEAN power out of the amp, simple as that. you either need a more powerful amp or subs that work better with the current amp you are using
what amp/subs do you have?
i use track 5 and its loud but i have voltage drop like hell an after about 45 sec to 1 min of hard bass i get the smell. i was told my electrical should support my system but idk. can anyone shed some light on this ?
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Looking at your sig you do not have enough electrical for 4k+ watts. I have about the same for 1500 watts..... just my choice. Add a battery or two. If you're dropping into 12s or 11s with bass its definitely losing a lot of power and would not seem as loud.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
really? i dont have enough? AQ said i did. whats the rule on that
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
With enough batteries I think he could pull off 4k on 220 amps.. But, i think 220 is a bit overkill for 1500. That's much better than not enough though ;)
Does your voltage drop at all?
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
I have a dc power 270xp, XS power d3400 and shuriken bt-35. Zero voltage drop. But when I was running 3k+ I did have some. It would drop to high 13s. And that was with a clamped 1,100 watts I think. Plus mids and highs. I'm not saying he needs to go crazy still but I would definitely add another big battery to his setup. And if he's getting a smell it sounds like he's dropping low to 12s or 11s which will cause clipping and destroy subwoofers.
Edited by Robert8252
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
