Any tips/tutorials for using Audacity?
Alright, so the other day I slowed down Rodeo by Juvenile and it sounded like complete garbage. I'm almost positive that it's because of the type of file I saved it as, so what type of file DO I save/export it as to get the best possible quality? I think I might've left it at the default accidentally.
did it sound fine before you exported it?
ctrl+p, change quality to both highsync, 32bit float, 44100hz
next import a song, go to export and hit options, use preset, quality insane/320kbps, variable speed fast
Will check that out later when I get back to campus, back at home now trying to get my system fixed xD
Go to Edit --> Quality
Look at bottom where the LAME encoder box is and change bit rate to 320.
Best Quality Audacity can do is in .wav format (Unless the release a .FLAC codec for it.)
Be warned that .wav files are relatively large and not all devices can play them.
that's why i just suggest mp3 @320
30mb wav songs are no bueno for most folk
Does that entail better quality though? I've got a 64GB iTouch to put music on haha, even with all of both of your guys' Zips + tons of other CDs that I have I don't even think I'm using 1/3 of my potential memory :P
EDIT: Just noticed that you said certain devices can't play .wav, would you happen to know if the Touch can play it?
supported formats on touch:
aac(8-320)
protected aac
he-acc
mp3(8-320)
mp3 vbr
audible 2, 3, 4, ea, ax, ax+
apple lossless
aiff
wav
for rap is rather pointless to use lossless/flac/wav because the bass drowns out the subtle nuances that those formats excel in
Bass boosting a song in audacity is very easy using the equalizer tool, just cut the mid/treble frequencies and boost the bass frequencies. If there is clipping in the song, undo and lower the bass a little bit until there is no clipping. Basically a trial and error thing. If you use headphones it is very easy to hear when it is clipping.
Alot of songs also have clipped bass to begin with (alot of Gucci Mane songs come to mind) which means no matter what you do with the equalizer tool, it will always be clipped.
I'm interested in making my own bass remixes after reading this thread now, though, should be fun. Always wanted to make my own remixes like bigpimpin does
this thread if meant for people who know what they are talking about
when you lower the amplitude of the wave with the EQ you are getting rid of the red and making the clipping quieter, but there will still be distortion from the clipping, you cannot fix that.
How is what I said any different from that? If a song is clipped in the first place, nothing will fix it, which is what I was saying
do you read before you type?
"lower the bass until there is no clipping", that's not possible and you are suggesting something know one else should follow
you are simply lowering the amplitude of the same waveform.... its analogous to turning the volume knob down a few notches
I swear, I'm in love with this thread. Thanks to everyone who's contributing, my boosts sound a lot better now :P I'll be working on creating bass lines, that's a bit tricky for me.
Oh, I see what you are referring to now
That was a communication error on my part, I meant it as in if there is clipping after using the equalizer tool, then to undo the change, lower the equalization sliders a little bit, and try it again. Hopefuly that was more clear, I didn't mean lower the bass on a song that was already clipped to begin with
