Ok so I'm designing a box for my buddie that we are going to build. I kinda got an idea but for the port, how do u find out the total length? I'm wanting the port inbetween the subs, but the port has to be 30" long, but my depth is only 14. I thought that when the port hits the back of the box, split it into to so there's a portbopening for each sub. Question on is how do I figure the length of the port, and also, if I do it this way, will each sub be in its own chamber or will it still b one big one? The port doesn't go from top of the box to the bottom, so they aren't completely sealed off. Also, will this cause the subs to b loaded on and add a lot of box rise?
Bring on the Rockfords!!
Well, it sounds like you are making this way more complicated than it has to be.
Either way it is MUCH easier to extend your slot port from the bottom to the top because not only will it be way easier to build the port walls will also act like bracing for your top and bottom pieces. I suggest either doing a nice slot port on the side or center port with a "T" shape at the back of the box to achieve your finishing length.
-Drew
uhoh_45 said:
What are your maximum dims and what subs are you using also what tuning frequency are you wanting.
Max is 41X14X16 and he is using 2 of the new Rockford P3D4-12's. He's wanting about 33 htz ish, he wants it as loud and hit as low ass possible, SQ isn't a huge thing, more towards SQL leaning more to the hard hitting side. He listens to chopped and screwed stuff and tech n9ne just to give an idea.
You are short on internal volume for that box so I recommend a side port design to save as much internal volume as possible, here is the suggestion:
Enclosure Specifications:
Fb = 35.026 Hz
Vb = 3.198 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 14 in
External Width = 41 in
External Depth = 16 in
Port Width = 3 1/4 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 37 x 12 1/2
Front Internal = 35 1/2 x 12 1/2
Back = 41 x 12 1/2
Left & Right Sides:
Side 1 = 14 1/2 x 12 1/2
Side 2 = 15 1/4 x 12 1/2
Top & Bottom = 41 x 16
L Port Internal Assembly Parts:
Front to Back = 11 1/4 x 12 1/2
Extension = 5 x 12 1/2
For a 33Hz tune the port changes as follows:
Fb = 33.008 Hz
Vb = 3.054 ft^3
Extension = 10 x 12 1/2
But beware that your net internal drops further
Assembly guide:
Any questions let me know.
  • Who's Online   0 Members, 0 Anonymous, 1347 Guests (See full list)
