steve volz Posted February 18, 2012 Author Report Share Posted February 18, 2012 what if i made the 2 middle ports 4inch? Quote http://www.stevemead...new-xfl-pg6-57/americanbass hd 12d22 audiopipe 1800.1ppi s580.4rockford p1653 frontpolk audio 6x9 rearbig 3 Link to comment Share on other sites More sharing options...
412 CVX Posted February 18, 2012 Report Share Posted February 18, 2012 Box making is not guess and check... do it right. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
steve volz Posted February 18, 2012 Author Report Share Posted February 18, 2012 i used the wrong box calc when i built my box and didnt think port area mattered as much as it does Quote http://www.stevemead...new-xfl-pg6-57/americanbass hd 12d22 audiopipe 1800.1ppi s580.4rockford p1653 frontpolk audio 6x9 rearbig 3 Link to comment Share on other sites More sharing options...
steve volz Posted February 18, 2012 Author Report Share Posted February 18, 2012 is there a difference in port area between a spl and a sound quality box? im going for quality Quote http://www.stevemead...new-xfl-pg6-57/americanbass hd 12d22 audiopipe 1800.1ppi s580.4rockford p1653 frontpolk audio 6x9 rearbig 3 Link to comment Share on other sites More sharing options...
Joe X Posted February 18, 2012 Report Share Posted February 18, 2012 Steve, I may be missing something but you started this thread complaining of distorted sound or "clipping", before you added the extra ports you were complaining about port whistling. My question is do you still have port whistling or not, because that's the main sympton of low port area NOT distorted sound which has nothing to do with port area on MOST cases. Better explain what you are experiencing right now, with what songs..what you listen..etc so that the proper advice can be given. Quote Link to comment Share on other sites More sharing options...
steve volz Posted February 18, 2012 Author Report Share Posted February 18, 2012 the whistling stoped when i added ports i just need to tune the amp. what I thought was clipping was my amp rack hitting the back of the box Quote http://www.stevemead...new-xfl-pg6-57/americanbass hd 12d22 audiopipe 1800.1ppi s580.4rockford p1653 frontpolk audio 6x9 rearbig 3 Link to comment Share on other sites More sharing options...
Joe X Posted February 18, 2012 Report Share Posted February 18, 2012 (edited) the whistling stoped when i added ports i just need to tune the amp. what I thought was clipping was my amp rack hitting the back of the box Ok so if you don't have whistling anymore then I don't think is th box, port area is not ideal below PA/Vb below 9 but being above 8 will cost you some efficiency but nothing more. Obviously if your box is hitting the amp and have any bad wires or bad connections you may be experiencing distortion when there's a lot of vibration going on, so you may need to check both your power and singnal cables to see if nothing is damaged or loose. There is a simple method to set your gains without any instruments, it's described in any rockford fosgate amplifier manual, are you familiar with that?? if not I will write it down here for you, it will be good enough for dealing with an obvious issue. Edited February 18, 2012 by Joe X Quote Link to comment Share on other sites More sharing options...
412 CVX Posted February 18, 2012 Report Share Posted February 18, 2012 the gain setting method without a DD-1/oscope is not ideal but i suppose it will have to do. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
HHR Ed Posted February 19, 2012 Report Share Posted February 19, 2012 did you seal the gap around the ports? Quote Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion Link to comment Share on other sites More sharing options...
