height 1 16, height 2 9.5, width 36, depth 1 8 depth 2 17
4 3inch ports 14inches
3 p3 10s audiopipe 1500.1d
Ok so your net effective volume is 3.2 cubic feet
Your tuning frequency is around 38Hz
PA/Vb = 8.8
RF spec is 1.4cuft@40Hz PA/Vb about 11
So you are short on net volume and port area but not sure that can explain your problem.
Do you have any electrical system upgrades?
Basically you need to go through a gain settings procedure to make sure you are not soft clipping.
1) you need to defeat all tone controls on the head unit and the amplifier, bass boost, and best disconnect the bass knob that the amp comes with
2) need to set the subsonic filter on the amp to nearly 30Hz.
3) go through a simple gains setting procedure, are you familiar with that?
Edited by Joe X
i have the bass all the way down and the treble all the way up on the deck. I know u can use a dmm to set the gain by using the squareroot of the rms/ohms but i dont know the rms at 2.67ohms the amp is 1500 at 1ohm 950 at 2ohms 600 at 4ohms but i dont know about the rest of the settings
and my ssf goes from off to 50hz would off be 0hz?
http://www.stevemead...new-xfl-pg6-57/americanbass hd 12d22 audiopipe 1800.1ppi s580.4rockford p1653 frontpolk audio 6x9 rearbig 3
Got any pics of said box?
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Ed Lester
ShowtimeSPL Host
My old Build Log
Well there's your problem lol.'
not enough port. maybe if they were flared you wouldn't have the scuffing. but it looks like a new box may be in order
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
  • Who's Online   0 Members, 0 Anonymous, 7334 Guests (See full list)
