XS Power
i have ordered a ctek 7002 charger because i have heard good things about this charger. what would you recommend me to do to try to get it back and revive it? it is currently sitting at 12.5v
xs power charger are crazy expensive.. yes i have one.. the entry level hf1215 unit.. still 200bux..
i bought a deltran battery tender and it does the job just as good.. never charges above 14v nice charger and it was like 40 bux
Actually no a battery tender can not do as good of a job. It just is not possible. A battery tender charges in low amperage and most of the time 2amps is the highest they go and most are actually 1 or .5amps. If you are charging small batteries this can be ok, but a 2 amp or smaller charge could take weeks to fully charge a Group 31 battery that is discharged. Low amperage is good to maintain a battery, but not to recharge a battery that has been discharged.
The maintainers charge at lower rates, which means they do not have the cost of internal materials that a 15 or 25amp charger has. Of course maintainers will be cheaper, because there is less cost associated with manufacturing them.
Edited by Nathan@XSPOWER
If it is sulfated the only way to try to break the sulfation up is to cycle the battery. Charge it up fully, then put a load on it. Do this cycle 4 or 5 times and see if it breaks it up enough to bring it back.
You could hook it up to your truck or if you have a load tester, just load test it and then charge it up. Do that about 4-5 times. If you want you can send it in here and I will see what I can do with it. I know you would have the shipping costs doing that, but I figured I would offer.
sounds good but the shipping will kill me since im in hawaii...lol... if i use my diehard platinum and charge it at 15amp, would that be okay or should i keep it at 2 amps? i am just not sure if the charger will charge it at full.
