XS Power
i have tried to charge one of my d3100 with a die hard platinum battery charger with the agm setting and charge rate at 2A slow. it charges the battery fine until it hits 77% @ 12.6 v and then says that the battery is bad. it is wierd cause when i check it with my dmm which has a load test and it says the battery is good. do you guys think the battery is bad or do i have a POS charger?
The load test function on a DMM will NOT test a battery. You need a true load tester.
And for the charger: It might just think it can't accept a charge because the d3100 is so big. It takes a lot of juice to top off a battery like that
Edited by SnowDrifter
cool... ill go get me a load tester to check it out and see what happens... i hope it isnt bad cause it is brand new... i forgot to mention that it currently sits at 12.6v... i havent hooked it up to my truck yet though.
I'd give it a full charge first. You might need to get a different charger
xs power charger are crazy expensive.. yes i have one.. the entry level hf1215 unit.. still 200bux..
i bought a deltran battery tender and it does the job just as good.. never charges above 14v nice charger and it was like 40 bux
  • Who's Online   1 Member, 0 Anonymous, 655 Guests (See full list)
