Which 4th order wall design should I go with?
So I will be using my new 10 15" Obsidians and am debating how I want the lay out of the subs. I will either be doing 4 on each side firing at each other with the baffles being on an angle and then having two subs in the very back firing forward or just do 5 subs per baffle on each side. Obviously both I will make sure have the proper airspace. I would like to put the two in the very back just because I would like the looks of that but just what opinions, pros/cons?
1946 Chevy Panel Truck: For Sale
1999 Ford Explorer XLT
Subs: Ten Obsidian Audio 15's
Sub Amps: Five American Bass 120.1's
Speakers: American Bass mids and selenium tweeters
Speaker Amp: Mb Quart Dsc4125
Electrical: DC power 250amp alt, 6 batteries
http://www.youtube.com/user/46panel
i would think cancellation with the 2 in the back
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Yea I didn't know what type of problems I might have with those two in the back. It's just I know twisted new build with the 6 15's has 4 on one side and then 2 in the back, and then jp's 10 18's is going to be like that but most designs like this I usually just see the subs on each side.
then it might work no problem
SCSB
Build logs:
look just like price setup
Yup, just 15's. But don't know if this design wouldnt be as good as just having them all on the side. I have the space to do whatever.
you people worry too much about cancellation. that only tends to be problem when you have really long tunnels with a lot small subs in them.
OP give me some dimensions, i'd love to make a sketchup model of this.
More box builds
I'm with captain stupid.
Well my tunnel will be pretty long. It is 59.5 deep, 30.5 tall, and 43.75 wide = 45.94 cubes then subtract .75 on each side for the amount of space the wheel wells took up on each side so 44.4 minus sub displacement which is 2 cubes so 42.4 then all bracing and baffle displacement (each baffle will be triple thick so 2.25") ill be right around 37-38 cubes. Planning on doing 15 sealed and whatever I end up with ported hopefully around 22ish.
Says which design I only see one
  • Who's Online   1 Member, 0 Anonymous, 1473 Guests (See full list)
