Crazycaraudio Posted February 22, 2012 Report Posted February 22, 2012 i was wondering if anybody can help me design or build me a box for a aq hdc315 which will be powered by a aq2200d. the deminsions i have are Length 32.5" Width 43" Height 25" i am not really sure on tuning i am going to be using this daily. im thinking between 35-38hz. Thanks in advanced
StrongmanDesigns Posted February 22, 2012 Report Posted February 22, 2012 I can design or build and ship. My boxes are made out of birch so cost much less to ship.
Joe X Posted February 22, 2012 Report Posted February 22, 2012 Ok here is a design suggestion: Enclosure Specifications: Fb = 36 Hz Vb = 4.2 ft^3 Subwoofer Mounting = Flush Mounted External Height = 17 in External Width = 39.25 in External Depth = 18 in Port Width = 4 1/8 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 34 3/8 x 15 1/2 Front Internal = 32 7/8 x 15 1/2 Back = 39 1/4 x 15 1/2 Left & Right Sides: Side 1 = 16 1/2 x 15 1/2 Side 2 = 17 1/4 x 15 1/2 Top & Bottom = 39 1/4 x 18 L Port Internal Assembly Parts: Front to Back = 12 3/8 x 15 1/2 Extension = 5 x 15 1/2 Assembly guide: Let me know any questions.
Crazycaraudio Posted February 22, 2012 Author Report Posted February 22, 2012 if i print this out and show the people at home depot would they be able to cut the wood to length? dont have tools lol
pa-pa-platypus Posted February 22, 2012 Report Posted February 22, 2012 if youre going to do that make sure you add a little bit..like and extra 1/2 inch.. theyre not exactly always the most accurate with their cuts sometimes ive seen em fuck up pretty bad cutting mdf for people edit: and maybe try to borrow someones circular saw for a day.. wont take too long to make the cuts This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
big dee Posted February 23, 2012 Report Posted February 23, 2012 You can get a saw at wallmart for 20 25 bucks. I wouldn't trust them to cut my box out. And if I did I would check it as its being cut . And if they miss cut I would have them redo it on there dime.
Brandonrcm Posted February 23, 2012 Report Posted February 23, 2012 Don't have the place cut the wood, the 2 times I had them cut for me fucked up alot
