How do you really "strap" two amps togehter? Can any amp be strap together with another of the same kind?
THE GRADUATE 10:18:2007
it needs to have a phase shift control.... attach your RCS and othere wire
use the + speaker wire from one with the phase contal set to normal, and the otehr amp use teh postive and flip teh phase contral to 180
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
whats strapping do
Subs- 2AA Arsenal 15sAmps- Orion2500d/MemphisDoors- Infinity kapa/AA polymids(soon)Deck- Pioneer PrimerBox- 3.5 per chamber!!!!!!!!/28hzElectrical- two optima red tops/160alt(big 3 soon)OHIO BABY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
whats strapping do
Doubles the power...For example if you were to strap two amps that do 2,000rms each you would then be getting 4,000rms using one amp basically.
[/quo
I already know that strapping doubles power, but what happens if I wire the amps to their lowest impedance then strap them will that even double more power?
I was answering bigarsenal's question.
I know you were but I was askin a question related to his.
thanks
If you lower an amp and the lowest they can run is 1ohm @ 2500rms then by strapping you will be doing 5000rms @ 1ohm.
actually, 2 amps that are strapped and shown a 1 ohm load will see a 1/2 ohm load each.  Other than that you guys are on the money especially SPLGEO ;)
Follow my Tweet (Twitter)
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
