Singer Alternator
run a gator back belt if you end up needed a new belt, those are known for making sqeaks go away
Well, turns out my belt is fine. I just had to tighten it a little bit more. This voltage thing is bugging me though..! who knew there was such a big difference between 750-1k rpm...
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
If u read carefully, I did say 'check a mechanic" and 'depending on your engine'. On some engines there is nothing wrong with adjusting it if it is incorrect, that's why they invented it, is it not? thus again i say check your mechanic
  • 10 months later...
Did you ever do anything to get that idled rpm up? I am having issues with my Singer Alternator not outputting its correct power when my car is idled and was thinking about upping the idle rpm by 100 or so.
you're lucky guys...try living with a car that idles at 550-600 rpm...if i had and idle of 650 i'd have no issues at all since i got an alt with pulley and stuff but too low idle...
'92 toy rolla EE90/AE92 1.3lt 12 x 8inch beyma (mids) 6 x beyma CP21-F tweeters(highs) 4 x 15 SPL Dynamics SPL380 D2(walled) 2 x ESX Vision 2500.2(mids,highs) 1 x SPL Dynamics D9-XS(subs) 4 x stinger SPV70 + 5 X SVR platinum 3500P batts 157.2 official on db drag comp-157.3 on same comp but eliminated...still a work in progress... Team Hxomania Trikala http://www.stevemeadedesigns.com/board/topic/156885-lil-noisy-toy-rolla/
No, I ended up saying eff it and threw my stock alt back in. I got sick and tired off low idle.
(1) Mechman 240
TEAM NWSPL
155db outlaw
Wow, bumping a thread from 10 months ago...
On the note of the idle screw, you need to bypass computer control of the idle before you adjust this screw. A HO alt can require considerably more power to turn under load, than a stock alternator. Also, the low idle may have been just a little too low to turn the alt on.
If the belt squeeled when turning, I'd say the belt was slipping, this can also affect the RPM of the alt at idle, possibly attributing to the alt not turning on properly.
2011 Chevrolet Aveo(click for build log)
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
Knukonceptz 1/0 Kollosus Fleks Cable
8 AWG Sky High Car Audio OFC
1/0- Sky High Car Audio
2- XP3000 XS Power Batteries
SMD VM-1
2- 12" Ascendant Audio Mayhems
Toolmaker Fuse block
Toolmaker Bus Bars
(Last Season scores 1-15" Mayhem)
145.2 dB- Sealed @ NSPL World Finals (9/28/14)
148.1 dB- Hardcore @ NSPL World Finals (9/27/14)
150.23-- Hardcore on 4500 Watts!!!!
New Build (2015, 2-12" Mayhems)
146.9- Sealed on dash
149.6 dB- Hardcore in Kick (No wall 0-24" Hardcore)
^^ thats what i was gonna say. at the same time to though the computer on the car could be the reason. i was having issues with low voltage and thought it was the alt. sent it in to singer and he tested it, tested it, took it apart and tested it agian. turns out my car didnt like the alt so now im gonna be going with an externally regulated alt with adjustable voltage. with this you can adjust the voltage up to the high 14s for comps and back down to the low 14s for daily driving.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
even if your idling low and making 14.x volts your still not getting FULL power from your alts.
i idle at 15.2v but if i turn it up ill drop into low 11s very easy, if i rev my truck i can go full tilt no issues..
basically.. at idle you have good voltage low amps.
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 1094 Guests (See full list)
