Running speakers only in front doors.
LoudBimmer
Since I will be cutting out my rear deck, where my 6.5's are, I don't want to replace them.
What I want to do is put 1 set of DD's in each door ( 2 6.5, 2 tweeters). If I do this, will I loose anything, sound wise?
Amp is sundown 100.4D.
I still want to have decent bass when I don't have subs in.
Also, does it matter how much space I leave behind 6.5's when making custom door panels?
Once you get used to having only front you'll never want to have rear fill again.
With good door deadening you'll get just as much midbass from the front as you would the rears.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
SS damp pro :)
i'm about to drop two set of those same comp's in a mustang fox body. in the doors. so let me know how you like it.
but to answer your question of depth. not much. since the mid is not a vented pole like that of a sub you could get the magnet pretty close with out dealing with any loading issues. but do allow breathing room around it. shallow and wide.
here is a set i had in my personal daily driver for some time. not the most ideal tweet location but i really wanted to maintain the factory piping on the door panel. and i don't have power windows.
NEUMAN
i just run speakers in my front doors, it sounds fine to me, there could be some rear fill but i dont mind it, just stock speakers for now, but i plan on doing two mids and a super tweet per door
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
I running front door speakers too now, because I took out rear deck.
Sounds OK, but the quality is not too good.
With DD's and upgraded amp it should make it much more clear.
But I'm not sure if I move rear deck speakers in rear doors, that it will give me same quality.
if its not enough for you. you can always od kicks as well. when i had my walled cavalier thats what i did. one in the doors one in the kicks.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1021 Guests (See full list)
