I have a 720p hp projector that i always used for my computer but wanna try hooking up my xbox 360 to it. It has a composite video in and a hdmi video also. I looked at the hdmi to vga converter boxes but they only support 800x600 max resolution. Any ideas?
Does the projector have a VGA in? If so, get the Xbox360 VGA cable, you can get them used at game stop for like 15 bucks and they work great! I used one for my homemade projector. And I I remember correctly, it the only true means of up converting the DVDs to hd.
why not just use hdmi? or do you have an older arcade?
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Go with Composite. Just be sure to use quality cables. HDMI, being a standard, the cables within the particular standard will provide the same signal. The main benefit of HDMI is cable management and support for high quality sound (bitstream).
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
But he won't get HD if he uses composite but he will if he uses the VGA cable.
I was reading up on these a little right now and people say the cheap cables add a lot of ghosting in menus and some during action parts and also can not support 720p and up. I might just try the true microsoft one and see how it goes, Im gonna use it for netflix in my theatre and definately for some gaming, cant wait to go out and get one!
Yea don't get the cheap ones from eBay, get the actual Microsoft one. And I got true HD on my projector, it looked great at 120"!
This shot was taken before I had done any tuning up to my projector (its a DIY projector so there was a lot of tuning to get it right)
