did you not read my post? voltage is over 13v most of the time... i dont even get to get to full tilt becasue of electrical and subs hitting xmax, bos still needs to be shrank
Is that 13v off the battery or off the amp?
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
right at the amps
its probably a rise issue. people with amps wired down into oblivion tend to roll up the volume while burping to not get the amps to protect. if they were to just press play with the volume full tilt, the amps will protect because, i assume, rise cant take into effect that quickly.
I rioll into volume for that reason there And rarely burp Its just a daily vehicle and does decent numbers which is a bonus
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Maybe clipping or over loading it.
I had this problem when I was going over my set volume25/35) by 2-3 clicks. I'm wired down to 1 ohm on saz2500.
Mine us 52/62 And sub at 0 I get to 52/62 ten sub volume to -10ish then protects Sometimes i get it a bit higher but then voltage really drops and i back off and keep voltage over 13v
Only way it can be from clipping is from clipped music Which is very possible
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 869 Guests (See full list)
