amps are at .7 strapped... what will casue the amps to protect on a quick kick drum or bass note? not enought time to rise? seems to be fine on "drawn out" bassnotes
amps are saz4500s
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
you are at .35 per amp? id assume that rise isnt there
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
with 2 amps strapped at .8 i rose to 2.2 ohm so i would assume rise would be less, with more amps no? sometimes its fine others not so much
i keep voltage around 13v, electrical is good.. but not up to par yet, 900A of alt and 8 batts ( 6 hc2400s and 2 oddesy 2150s)
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
i think u need more electrical! :peepwall: if you still got the 4 4500s in there
Edited by CortezDTV
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
i think its your load. I hate when people say that your amp will never see the load you wire to when it most certainly does. I dont think tis electrical. if you maintain decent voltage
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Rising to 2.2 ohms at what frequency? If the thumps are at or near the tuning point of your box, you won't be rising much at all (maybe to 1 ohm, if that). Don't count on rise to save you on music as it is dependent on the frequency being played. Oh, and if your coil jumps out of the magnetic gap: say goodbye to rise. The impedance will drop to nominal.
Edit: Where are you checking voltage? Batts or amp? Check it at the amp.
Edited by SnowDrifter
right at the amps
the subs are gettin it.. ill have a vid of some excursion SA10s vs 1500-2k daily ftw
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Maybe it can't take .35 daily? Assuming because I'm having the same issue with my bc3500, voltage drops, amp shuts off for a mili second and turns back on whenever it drops a low note.
Edit - voltage drops going to the amp, and barely drops on my battery.....kinda confusing but you'll get it of you really think about it.
Edited by carlosg_313
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
did you not read my post? voltage is over 13v most of the time... i dont even get to get to full tilt becasue of electrical and subs hitting xmax, bos still needs to be shrank
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
its probably a rise issue. people with amps wired down into oblivion tend to roll up the volume while burping to not get the amps to protect. if they were to just press play with the volume full tilt, the amps will protect because, i assume, rise cant take into effect that quickly.
  • Who's Online   0 Members, 0 Anonymous, 790 Guests (See full list)
