Decaf Posted February 27, 2012 Report Posted February 27, 2012 (edited) Loudness: Mid (without it I get hardly any bass) Subwoofer 2: 125 hz (currently +6) I think those would be the only two that effect sub? Any other ones you can think of or need? turn loudness off... no matter what you think, turn it off. its only meant to be used on low volumes Why at 125hz? How about 80/100hz instead, cant imagine the subs enjoy playing that high. Sub level should be at 0. When I had that unit I could go 38 clean. Last few volume clicks accounted for more than 1volt of signal. reset everything with EQ flat, no bass boost, using -5dB or -10dB. you might have been used to a lot of clipping with your previous setup. Edited February 27, 2012 by Decaf Quote
IKnowImLost224 Posted February 27, 2012 Author Report Posted February 27, 2012 Well, when it's off I don't get hardly anything Quote
Decaf Posted February 27, 2012 Report Posted February 27, 2012 Well, when it's off I don't get hardly anything deal with it, its not needed at all. there are other issues causing low output and that will not solve the problem Quote
IKnowImLost224 Posted February 27, 2012 Author Report Posted February 27, 2012 Thanks a lot decaf, I'll go through and do it tomorrow. I'm in class till 10 tonight so it will be a little cold and dark. I could go up to 58 out of 62 with a clean signal Quote
IKnowImLost224 Posted February 27, 2012 Author Report Posted February 27, 2012 What would be better? -5 or -10 db? Quote
Decaf Posted February 27, 2012 Report Posted February 27, 2012 (edited) Thanks a lot decaf, I'll go through and do it tomorrow. I'm in class till 10 tonight so it will be a little cold and dark. I could go up to 58 out of 62 with a clean signal If I remember the mvh goes up to volume 40. most newer pioneers that go to volume 62 are clean to volume 58-62 make sure you are not using no bass boost on the headunit either -5dB is quieter but safer -10dB is whats recommended for most users. if you play my crap you should use -5dB Edited February 27, 2012 by Decaf Quote
IKnowImLost224 Posted February 27, 2012 Author Report Posted February 27, 2012 What kind of music do you make? Yeah this one goes up to 62. Quote
Decaf Posted February 27, 2012 Report Posted February 27, 2012 What kind of music do you make? Yeah this one goes up to 62. disregard it, i dont make anything.... if the mvh goes to 62 and you tested it clean to 58 then use 58. if you have speakers hooked up the the headunit then thats a different story, you can only go up as high as they sound good. you can use the dd-1 to test the headunits amp if you disconnect the speakers. Quote
Skullz Posted February 28, 2012 Report Posted February 28, 2012 Just turn on the subwoofer output and turn the crossover off and set the gain from the sub out to max and see if you gain anything, if nothing still has changed try switching the phase and see if it helps. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
95legwagon Posted February 28, 2012 Report Posted February 28, 2012 (edited) decaf FTMFW!! edit: had ta remove some stuff lol how about a bad set of rca's? i know if you only hook up 1 channel to a sub amp usually itll be quiet as hell....had that happen with my setup and it sounded like ass..... try a different set of rca's Edited February 28, 2012 by 95legwagon Quote i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
