Kidd_Bass Posted March 13, 2012 Report Posted March 13, 2012 Max Dimensions 28 inches for the Length, 22 inches to the the window line (height) and 47 inches from side to side (width) Fi BTL 18" Soundstream Rub.2500 PM Me or Reply ......just need help with first box Oh and its the old Fi BTL UFO Model Dual 1 ohm If that helps If you need more info just tell me
carshateme Posted March 13, 2012 Report Posted March 13, 2012 (2) SA-10s 1 AQ 2200D at either 1 ohm or .5 ohms so 1100 watts per sub before rise 33hzz tuning pontiac g6 sedan trunk max specs height 15 width 30 depth 18 slot port think i got it all Here you go Mike. Box: 15h x 30w x 18d Port: 13.5h x 2.875w x 30.75d (Actual port length 27.13") Tuned: 33.14hz If you want the layout, pm me. New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
Jessica Posted March 13, 2012 Report Posted March 13, 2012 Kewwood w3013ps X2 vas(liter) 83.7 fs(hz)( 25 qts .82 xmax (MM) 15.1 tuned to 33 is fine or 35 i just need to bring up the low end and dont want a one note wonder. Looking for a slot port for a 87 accord hatchback Not sure if subs should fire up or rear but current sealed box is loudest fire-ing rear max width 34" max height 15" I guess I'll drop in, not the best, but I can help with these requests. I'll get this one. Since no depth was stated, 22.5" is the set depth. Tuned to 33.73hz Thanks. Much appreciated! and depth wasnt an issue so this will work great. One question will it change anything if i fire the subs up? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
carshateme Posted March 13, 2012 Report Posted March 13, 2012 Id put a corner piece along the bottom piece where the current sub cut out is. If you look at the design for papaslim. Its similar to that. Elsewise no it wont change anything. New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
Jessica Posted March 13, 2012 Report Posted March 13, 2012 Id put a corner piece along the bottom piece where the current sub cut out is. If you look at the design for papaslim. Its similar to that. Elsewise no it wont change anything. cool beans, thanks again Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
carshateme Posted March 13, 2012 Report Posted March 13, 2012 No problem. New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
412 CVX Posted March 13, 2012 Report Posted March 13, 2012 Dayum, double baffle on some 1000 watt subs? lol goin hard mr. troll Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
teardrop Posted March 13, 2012 Author Report Posted March 13, 2012 here ya go sid How big is that port area? Looks small Can you give me the specs of the box. tuned to 33 hz 13.8 of port per cube
teardrop Posted March 13, 2012 Author Report Posted March 13, 2012 DC level 4 with level 5 upgrades 10" Mounting Depth 6.25" Mounting Hole Diameter 9.25" Outside Driver Diameter 11.0" Motor Width 7.75" Weight 32lbs VC Diameter 3" Displacement .16³ ft Magnet Weight 29lbs Power Handling RMS/Peak 1400/2800 2000/4000 w/ upgrade Ohm wired at 1 Sd Vas Cms Mms Fs BL Re Le Qms Qes Qts Xmax 23.5 mm Ref SPL @ 1 watt Suggested Sealed .75³ ft Suggested Ported 1³ ft My amp is a atomic 1000.1 Max demintions Width 57" Height 18" Bottom depth 8" Top depth 4.5" I know you said you liked to do big boxes but if you can point me in a vicinity I'll be happy. Thanks you dont have enuf depth for mounting the sub
carshateme Posted March 13, 2012 Report Posted March 13, 2012 Dayum, double baffle on some 1000 watt subs? lol goin hard mr. troll Hell yeah, Lol. =) go hard or go home New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
