Yea i know the box is doubled up. i made it that way to someday upgrade and get 2 more 15's then it would allow each sub 3.5 cf but for now i only have 2.
So im assuming thats the reason i cant get low is because the box is to monster.
you are correct, the box is way to big for your 15's, changing the port will do nothing to improve the lows at this point. the only way your going to see any kind of audible difference is when you get those other two subs.
no. that isnt the reason
in a wall the car determines the tuning. the port length only changes the bandwidth
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Add two woofers.
Or,
Cut the volume in half.
-Drew
uhoh_45 said:
more cone will help. move the wall back if you can
different car perhaps
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Okay well i guess i will have to get some money together for another 2 subs and another t1000 amp uhgg this is getting expensive..
The wall is as far back in the car as i could get it.
Walled 2002 buick century A.K.A "Betty sue"
polk 5 1/2 front doors
4 3in pillar speakers
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
:build: http://www.stevemeadedesigns.com/board/topic/162721-buick-built-in-trunk-fi-sp4-hifonics-2400/
i took this vid with the 15in long port that i made :( it didnt shake a thing in my car or get near as loud as it was with no port. so i took it back out. uhgg 2 more subs and an amp it is .
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
No offense but man that just looks like a big box sitting on your rear seat. Get two more woofers in and sealed off and you will be much happier, even if they are running on below rated power you'll have much better results. -Drew
Edited by Noobtastic14
