are you running the kicker in ur sig?
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
I just put in the xtx5000.1 but im worried about running it because of voltage issues.
2005 ford explorer xlt limited 4x4
2 xs power d3400s
2 runs of shca
mid/ highs- infinity 6x8 3 ways
2 18 ssa icons
2 aq 1200.1 @ 2 ohms
10 cubes tuned to 36 hrz
looks to be rated at 2500.. id say the yeller top up front, big 3, and biggest you can afford for the back you should be fine on batts.. just make sure like started before you keep em charged up
power: dd m4
That makes me very happy. Thank you for your help.
2 xs power d3400s
2 runs of shca
2 18 ssa icons
well youre running it at 1 ohm i take it?
and dont skimp on the back batt either if you have to save up then save up..no need to burn the amp up from low voltage
Edited by aqsubowner1990
power: dd m4
is optima and xs power a good combination ???????
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
They will work. however im anal retentive about this and I couldnt stand the thought of running two different brands of batteries.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 2747 Guests (See full list)
