Can i put 1 sub facing up, and one facing down (not inverted)
Can I have a box mounted vertically with 1 sub facing up towards the roof, and 1 pointing down towards the floor, 2 ports out either side ?
box is going between the seats of a regular cab ranger, 1 sub up, 1 sub down, and 2 ports going behind either seat.
will this be ok, kind of a weird set-up, I dont think it should effect the sound much, as the cabin is so small, but who am I ? Some guy hoping the experts can help :)
I don't think it will be bad but could you put one facing up and the other facing back, I think that would sound better
Duel Sa-8 V.2 D2 Sub Enclosure
2001 Pontiac Grand am
  • Head Unit - OEM
  • Processor - RF 3sixty.2
  • Subs - RE Audio SXX12D4
  • Amplifier - Kicker ZX1000.1
  • Mids & Highs- Rockford Fosgate Power T2652-S
  • Rockford Fosgate Power T1693
  • Mids & Highs Amp - Rockford Fosgate Power T400-4
  • Wiring - 1/0 AWG, 4 AWG, 8 AWG
  • Alternator - Stock
  • Batteries - non ext
  • Box- Absolute PSEB12BK
edit nvm didnt read title correctly
Edited by Socky
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
I did a setup like this for my center console box in my f250. What I noticed was the sub firing forward excurted more and kind of bottomed out because the sub facing down was pushing it out more because it had nothing to "load" off of while the one facing down was "loading" off the floor. This could be wrong or just a million in one. Chance of it happening but that's What I noticed.
BABYJUICE
Should work fine if its whats you want to do . Im pretty sure you would have to reverse the polarities for them not to cancel.
SuperBass
check out⊂ http://www.youtube.com/Bassknots
129.3 meca 136.8 db drag (60 hz peak)
http://bassknotsstereo.blogspot.com/
comment/subscribe and stay tuned ,working on 150 db http://www.stevemead...r/page__st__380
I dont have the space for any other configuration. it is a regular cab ranger, could do 1 up and 1 forward, but it is a stick shift, and i would be hitting the sub with my elbow. subs are SA-8's if it matters.
and thanks for the input guys.
what if you made a arm rest out of the port..you could set the the subs faces forward with the port
R.I.P...99'Dodge Grand Caravan
03 Lancer Oz
Big 3
HU-JVC KD-530
RCA's-rockerfosgate
41/2 inch Infinity mids
Subs-(12's)2 Orion xtr124
Amp-Coustic600se
battery-2 x stock, 1x Shuriken SK-BT20
Box-L-ported 3.562cubes@35Hz
miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive)
I dont have flex yet but damn I sound good,(coming soon....flex)
Check out my HHR install
Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/
Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
why would i have to reverse the polaritys ? both subs will be mounted in the box the same way. just pointigng different directions .
as far as loading the bottom sub firing at the floor, I am going to split the difference, the sub firing up will be 5" from the roof, and the sub firing down will be 5" from the floor.
litteraly guys, I have no room, my box is 9.5x9.5x27. It touches the inside of both of my seats and the back wall. I can either mount 1 on the bottom and 1 on top, or 1 on top and 1 forward, but like i said, if i put one forward, then my elbow will be touching it.
If I put the port forward, and tryed to build a console, the counsole would either be too high, hit my shifter, or be too shallow, and i needs me a center counsole to hold shit.
Edited by lilwillywilly
  • Who's Online   1 Member, 0 Anonymous, 1762 Guests (See full list)
