Look what I found!!!!!
Those crossovers are only meant for a midrange and tweeter and they are wired in after your amp. If your running a stock amp forget about the crossovers completely. OrionStang is right on the money don't try and mix and match a stock system, most people here are trying to help you not bag on you.
i meant put it after my MBQuart 1500.1D I have my subs hooked up to. But if i do that it will be putting around 1000 RMS into the crossover from the MBQuart amp and i dont know if that is too much RMS for the crossover to handle
So are you trying to run the crossovers to your subs or take that amp and switch it to run your mids and highs?
im just trying to add two 6 1/2" speakers to the 2 6x9's i have to give me more sound to keep up with the 4 10s i just put in. what is the easiest way to add two 6 1/2" speakers. thats all im trying to do
Car
1999 Dodge Stratus 2.5L V6
Deck
Kenwood DDX-512 Head Unit
Doors
(2) Diamond Audio DA6.6 6.5's
(2) Cerwin Vega 3" Horn Tweeters
(1) Alpine MRP-F240 for Doors & Tweets
Rear Deck(on factory wiring)
(2) JVC 6.5's
(2) Rockford Fosgate 6x9's
Subs firing forward
(2) Skar Audio VVX-12's
(1) MBQuart ONX1500.1D for Subs
Wiring
Cadence 4AWG for MBQuart Amp
Advance Auto 8 AWG for Alpine Amp
Cadence and Monster 4 AWG Wire to Kinetic HC1200
Batteries
Stock Replacement up front
Kinetic HC1200 in the back for the amps.
And yes "I drive a Dodge Stratus"
Here is my build log:
http://www.stevemead...__fromsearch__1
Ok, I really think you need to defeat your stock amp. Your MBQuart amp is a (sub amp) and should only be hooked up to your subs. Its a class D mono block amp that should never run your highs. Leave that going to your subs. You should really look into adding a 4 channel amp, look into a 4 channel MB amp. After you get this wired in you can hook up each of your speakers to a channel and be doing it correctly.
The easiest way for you to add the 6 1/2's would just be to install a 4 channel. Forget using the factory amp and factory head unit. MB Quart makes great budget 4 channel amplifiers.
What I'm getting from how you've explained all of this is you cant use the factory wiring for your front speakers because there's a short somewhere, so you can only use the rears which currently have speakers hooked up on them, correct? If so, just forget about hooking up the 6 1/2's with the 6x9's. Use your bass amp to power your tens, and just invest in a new headunit and small 4 channel. If you wired the 6 1/2's on the same power as the 6x9's from the factory amp, you'd have massive impedance issues.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
  • Who's Online   1 Member, 0 Anonymous, 1122 Guests (See full list)
