About to install my first system, any tips?
i'm not gonna touch the setting for bass boost on the amp. Is the knob also a bad idea, or is it ok when used minimally?
read
if the knob is a remote gain its good to use if its bass boost dont even use it.
most companies like hifonics and others use a bass boost knob. which you dont want to use. some companies like audioque use a gain knob, which if turned to max, doesnt exceed the gain setting on the amp itself. its just an attenuator.
Good grounds
Dont run rcas with power wire
Good solid connections
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
read
the hifonics knob is also a remote gain
read
I have the MB Quart 1500 watt amp. Being a maxxsonics company it is a bass boost knob?
I own and operate the BRZ1200.1 and i can safely say the knob is a gain knob..
play a tone at anything other than 45 and adjust the gain knob, if it gets louder than its a gain knob.
bass boost on the BRZ series is 45hz so it would be really obvious if it was turned up and the gain was down
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
SPL tape is your friend. Just don't get carried away.. lol
corrected ;)
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
double check all connections, youd be surprised what you can miss and duct tape is conductive so make sure you dont secure or clean up any connections with it.. with that being said, it's still your best friend when you dont want to reassemble your whole car to go get 2 brackets
  • Who's Online   1 Member, 0 Anonymous, 1222 Guests (See full list)
