Cool... if i do end up picking up the amplifier, i will probably just run it at 2 ohms... i am trying to get power equivalent to my two sundown 3k's... the only reason why i am looking for a different amp is cause i am trying to save me some space where i mounted them
There is no other way to mount the sundown 3ks differently ?
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
this is how i have them mounted... i had them side by side but it would be hard to run my 0 awg wires...
my problem is that my 4 channel amp is sticking up a little too high and it hits the bottom of my bedcover... since the piece covering the amplifier is 3/4" thick (scrap from my box) I think I will buy 1/2" mdf instead... I'm hoping that will work.
If I just got one amplifier instead, it is guaranteed that it will fit with no problem
Edited by nosho47
I would stick with the 3ks. Use 1/2 " like u said. Those amps will do more than that stetsom. And cleaner.
HMU!!!
95 Bonneville SSE
You could angle the amps, fit way better and have more room for cooling
Hammerdown... 1%
^ this
Mount all 3 amps at like a 45 degree angle a few inches apart and it looks like you'd have enough room
Ehhh im going to have to disagree. Stetsom is known for putting out big power at lower voltage and high impedance which is where they will pass up alot of amps.
I am alot bigger of a fan of the k2d model then the k2e
- 1998 Ford Mustang -
Time to rebuild.
4 15s and alot of power
TEAM DTF
