So i have 2 dual 2 ohm subs trying to do a 2 ohm link master/slave on 2 saz 2500s. In the manual it shows a picture of how to do it with 1 sub, so how do you do it with 2? Common sense tells me to just run the other subs to the other inputs, but im not 100% sure.
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
You create a two ohm load and then do what the manual says.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
positive on master is positive for speakers
positive on slave is negative for speakers
connect master negative to slave negative to complete the strapping
gotcha, i thought it was a 1 ohm load to each amp, now it makes sense :)
Team gg.
connect them like this run the + to the master - to the slave.
:) thanks ya'll i actually found some more threads like this, things go thru my head sitting in a college's computer lab lol
Team gg.
dont mess up the series/parallel wiring like you did with the AQs.... :P
HAHAHAHA i can laugh it off now...cept my subs will blow now cuz of my port :( ahhhh
Team gg.
Yeah that's the thread I used to. Make sure it's wired up right though... I messed my wiring up and had each amp at .125 smh. But I just got the amp back from repair and now it's wired at .5 per amp and running strong. Not as loud but a lot more stable lol.
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
