Today I did a lil testing on the tl.. 1st burp I gained .2 did a 156.8...starting voltage was 16.2 and barely dropped.well after that dbs dropped to 156.3 and voltage was dropping a lot... also charging voltage dropped to 15.6...do you guys think I have bad connection..I have 3 alts 6 batterys and 10 runs of 0g..I mean could corrosion build up and cause a drop under heavy pull? Did batteries just get low? It was weird never had such a big drop before..it usually is just a tenth or 2
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
how long between burps?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I keep rpms up to at least 2k plus.. only like a minute between :-)
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
only do it once or does it do the same thing every time, even after giving it time to charge?
Could be voltage but seems like it would more gradual. Are your runs fused? Id check all connections for anything old.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I don't drive above 16.2 cause it messes with my steering and I was too lazy to adjust it up..I've heard of spl competitors that clean all there connections after every burp..well I was dipping pretty hard at autorama..cleaned my frame grounds and it got much better..I'm goin to clean all battery bussbar connections and see what happens..like I said maybe batterys just drained quick. It was weird thos voltage was a stable 16.2 but after 1 or 2 burps dropped to 15.6.. maybe heat? I don't know
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I'm running all 14v..and yes it affect my steering sensor which in turn opens up power steering fluid flow and makes my steering very light at high speeds which is dangerous...it will switch lanes on me etc...
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
again. did it charge back up or stay at 15v?
  • Who's Online   0 Members, 0 Anonymous, 2887 Guests (See full list)
