I need a new box design. For a Pontiac g6 with 2 sa 10s off a aq 2200D at 1 ohm or .5 ohms. this is for daily use. I would like to get it as loud as possible but still sound good. tuning i think should stay between the 28 - 35 hz mark. not sure on vehicle peak freq at.
max dimensions are
Height- 15
Width- 30
Depth- 17
sketch ups would help too thanks!
Edited by MIKE-2U
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
edited
That amp is too much power for those subs better add subs or use higher power subs, anyways here is a suggestion aimed at higher power use (but not 2200W RMS), port/subs front firing or back firing can be tried:
Enclosure Specifications:
Fb = 34.005 Hz
Vb = 2.46 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 15 in
External Width = 30 in
External Depth = 17 in
Port Width = 2 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 26 1/2 x 13 1/2
Front Internal = 25 x 13 1/2
Back = 30 x 13 1/2
Left & Right Sides:
Side 1 = 15 1/2 x 13 1/2
Side 2 = 16 1/4 x 13 1/2
Top & Bottom = 30 x 17
L Port Internal Assembly Parts:
Front to Back = 12 3/4 x 13 1/2
Extension = 11 3/4 x 13 1/2
Assembly guide (generic dimensions):
Set your subsonic filter to 25Hz to help protect the subs.
Let me know any questions.
Its not to much power as long as its clean. I have ryan on this as well and i am just getting a collection of designs then i will build.
And I agree but you must have superb power and system tuning... also you are still exposed to a slight mishap.
A couple of Fi SSD 10" not substantially more expensive would fit you amp better and probably sound nicer...
why are you only going 30 wide? i did a system in a g6 not to long ago and the box i built was near 40 iirc.
NEUMAN
my girls box is 38" wide.. i went wider to save on depth.. bc a g6 doesnt have a very big trunk
I want to be able to take it out in need of spare tire. And if it can be built wider than ok i just threw dimensions of my old box
Any od you still have plans for them?
Lol something wrong with the one I made you?
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
  • Who's Online   0 Members, 0 Anonymous, 2930 Guests (See full list)
