need help with box please
jeffrm
those are the specs. any help will be appreciated
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
CVX just told you to pm him. I would sketch you up a design, but I'm getting off.
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
I did keeping this alive just in case
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
You have enough airspace to do any of them, I just picked the following since you have the space:
4.5ft3 2(4” ports x 10 ¾” long) (34Hz) F3=37Hz 1000w
So all that is left to do is make it fit your dims, Also choosing port up/sub up, can work (among others) and is easy to build:
Enclosure Specifications:
Fb = 34 Hz
Vb = 9.045 ft^3
External Height = 24 in
External Width = 44.5 in
External Depth = 22 in
Port Width = 7 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 44 1/2 x 22
Left & Right Sides = 20 1/2 x 21 3/4
Front & Back = 44 1/2 x 21 3/4
L Port Internal Assembly Parts:
Top to Bottom = 14 3/4 x 20 1/2
The pic is generic only to give you an idea. A custom one can be provided if you want.
would this work
port
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
The port width to height ratio should be below 9 so that is a design fault, you are at about 12.1.
Also I would do some front to back cross bracing between the subs.
For a ground pounding sound, not spl I would do the largest size suggestion and keep tuning lower as they recommend (34Hz). Also the larger enclosure makes sense on below rated power.
If you didn't like the port/sub up suggestion I left you probably a front center port and subs front can be tried.
would this work
port
Hey, not to pick on you or anything, but you know if you hit print screen on your keyboard and open paint and click paste, you can upload that picture without taking a picture of your screen with a camera =P
Then you can use imageshack.us, photobucket.com, tinypic.com...or some other uploading website to post the picture on this website.
But that port ratio is a little too big. Great design, but it just wouldn't do the trick.
so can any one adjust my design i like the way it is and if possible make my depth and height the same so i can face forward or up. 22in would be best tall and deep
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
if you could be a little more patient and tell me exactly what you want, i can do a design for you.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
