Well I got fed up with having to trim wire to make it fit in my amp(actualy I just was bored and wanted somthing to do), so I made some 1/0 to 4 gauge reducers out of some aluminum. Made these on a manually operated milling machine. Il post some higher resolution pictures later.
Edited by bobobass
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
is that tip square?
the problem i always have with people putting a solid metal bar into an amp is that it will always have much much less contact area compared to just wire. now if yours is square, then its even more of a problem. it would be better to run 4awg if that's the case.
is that tip square?
agreed. now youre only going to have contact on the 4 corners and where the screw sets on the square. this will create resistance, which creates heat. great first try but make them round for future parts. i wouldnt use those adapters for the same reasons skittles said, they prolly wont even have as much surface contact as 4 gauge
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Yeah unless you are real good and you can form it to the size of the terminal and then make the set screw thread into the adapter I'm just not a fan of them.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
That was deffinitly somthing I overlooked. Luckily I made the side that gose to the amp on each one I made slightly oversized so I could grind it down to get a good fit. I probably have enough material there to round it out. Hopefully I can save these. If not, they only took about 30 minuets to make. I can make more.
front stage: tbd
that's a great idea. Probably make some like that tomarow if I have time.
front stage: tbd
if you look at two difference sized circles on top of one another, you will see that they touch at the bottom and quickly separate. so to get an acceptable contact area you need to be extremely accurate on the size of the insert. give it a shot, little projects are always fun.
exactly what skittles said. IF you cant make it a perfect fit you are losing effective surface area.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
yea, I'm going to start inn the new ones tomorrow. Wish me luck, I'll post pics of the process
front stage: tbd
  • Who's Online   0 Members, 0 Anonymous, 1012 Guests (See full list)
