You will be fine with 1.6 cubic feet. I'm not convinced that it will make or break it.
I was looking more towards slotted.. How's this look.. anyone?
Uploaded with ImageShack.us
Damnit, i just noticed it'snot enough area of port.
how do you find the woofer displacement?
i'm trying to build a box for a mayhem 12 thats why i ask....i wonder if that box will work? what do you think?
You have to look at how much cubic they need man, the recommended specs.. like mine need 1.5 so you want to get .04 or less away from that, while being at the tuning you want, and be able to fit it in your car. It gets time consuming I've been trying for hours.
EDIT: to answer your question, the box will most likely not work for you because your sub needs a different amount of cubic.
Edited by TheNewbie
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
Right 11.5 in, find this at the bottom:
L Port Internal Assembly Parts:
Front to Back = 14 1/2 x 11 1/2
Extension = 14 1/4 x 11 1/2
Calculators have their differences but you are doing a port upwards.
Okay, then you have your length for the port at 33.75 correct to get to that tuning.. Correct? I'll put up on google the cutout sheets I need and put them together make sure they work, on your sketch it's just a tad confusing for me being that the front, and rear are bigger than the sides.. height wise. Sorry if I'm just not reading something right tends to be confusing for me.
Looking at the sketch, it seems if i put the board on their it would fit flush, Just confused on what cuts to follow and what ones not too. Just not sure if I base it off the torres calc can I go by the "cut sheet list"
Edited by TheNewbie
  • Who's Online   0 Members, 0 Anonymous, 1379 Guests (See full list)
