I'm running 4 sundown zv3 15's on 4 dd m2a's. I've got one sub output on my Kdc-x994, as of right now I'm using a Maxxlink. But it doesn't like 15+ volts. So my two options are two splitters then strap the amps. Or six splitters and one amp per sub.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
so the maxxlink sucks because it dosent like 15+volts ? Did you check to see what type of voltage was rated for before you purchased it? Like saying a 1 ohm stable amp sucks because its not stable down to .35. go figure
:ninja:
Edited by sensai_v3.6
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
My voltage wasn't supposed to go over 15v, but the alt I bought charges at 15.2v. So yes for my application it sucks. That's my opinion and I'm allowed to have it. But that wasn't the question that got asked. Thanks for reading.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
dual alts.
i would say the alt sucks then since the alt you bought wasn't supposed to go over 15 and it goes over 15. :unknw: What is the purpose of you using the maxxlink ? Maybe we can see if there is something else that can work in your application.
:ninja:
also if you are saying it sucks for your application then i would put that in the title because the reasons you have for saying the maxxlink sucks are really not valid. I just don't like someone to bash a product when really there is no reason to bash it.. especially when the product is functioning like its supposed to and not acting right based on another product that was purchased that is going over what was said it WOUDNT do..
:ninja:
I bought the alt from pstone on here, it was used. I bought it to use in a dual alt setup. But back to your question of why I bought the Maxxlink. As stated above I have a Kenwood kdc-x994 that had only one sub output. I'm running four sub amps. One per sub. After I put the alt on and noticed the problem I called maxsonics tech support, I explained to them the situation and they said a lot of big SPL guys are using them in 17volt systems.
I unhooked the second alt that was charging over 15 and it worked fine, but once its connected again and the voltage goes back up the Maxxlink shuts down. After some research, I found that I'm not the only one that has had trouble with the Maxxlink at 15+ volts. Others have used them without failure.
I bought the Maxxlink because I didn't want to use splitters. But in order to use the dual alt setup, something has to change. That's why I'm tossing around the ideas of 2 subs on 2 amps strapped, or just run the six splitters and keep it 1 amp per sub.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
dual alts.
try to find a 4 channel line driver or look at a 2 channel and just strap da amps. I will see if i can get a list of line drivers for you.
:ninja:
Is it the MLX-100?
Put some diodes or a resistor on the power line.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1134 Guests (See full list)
