AA98hoe Posted March 19, 2012 Report Posted March 19, 2012 How's it leakn? Did you cut the hole wrong? Isn't there a gasket on the sub? You can use the caulk cord or the gasket material..but gorrilla tape works on the outer edge well if your flush mounted Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
SnowDrifter Posted March 19, 2012 Report Posted March 19, 2012 I've used hot glue for that before lol. Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
bigboomin Posted March 19, 2012 Report Posted March 19, 2012 Do it the right way and pull the sub Quote
Decaf Posted March 19, 2012 Report Posted March 19, 2012 Do it the right way and pull the sub si, weather stripping and rope caulk will only work if the sub is taken out Quote
BEEMDUB Posted March 20, 2012 Author Report Posted March 20, 2012 just pulled my subs out and put the weather stripping underneath of them..........it was freakin HELL took my about an hour and a lot of sweat... Quote
Quiet Posted March 20, 2012 Report Posted March 20, 2012 good man. I used weather stripping for my sub and my front stage. Totally worth $5. Quote 2007 Pacifica Rebuild. Less quiet. Still not loud.
BEEMDUB Posted March 20, 2012 Author Report Posted March 20, 2012 Yea of course with my luck I still have a couple of leaky spots but I'm gonna fix em tomorrow they're not that bad and not even close to how bad it was before I sealed it..... And I lost about 1-2 tnuts on each sub when I removed the subs they fell out Quote
